Originally posted by PentaxPoke Wow that black bird is beautiful. If RAW would help you pull out more feathers where jpeg would not, I'm sold! I'll be interested to see your results.
Thanks,
Regarding the RAW vs JPEG, and saving images, the reason I posted this is it is the real exception.
I normally take the approach of getting the JPEG perfet, i.e. lighting and contrast. This is a really bad subject because the bird really is black. I think the only way to do anyting, is shoot raw in this case, and use the extra resolution (12 bits vs 8) to try for a little more detail.
Normally JPEG suites me fine specifically when the detail is spread over the entire dynamic range. like the shot below. I don't have any issue with this, and it is right out of the camera, except for resizing.
https://www.pentaxforums.com/forums/187646-post19.html
But when detail is all really confined within 1 stop at either endo fht e dynamic range, raw may be a better option. I'm inclined to think next time, I'll push the raw button as a back up on the black birds. (by the way, I don't really have a problem with the shot). My next one will be in flight head on. That will take some time.
With respect to the general issue, if properly exposed, I also have not had any problem making color corrections in JPEG
