Originally posted by mee I'm curious how this occurs.. when taking a photo, the viewfinder is obscured by the mirror which flips up to expose the sensor.. so is the mirror simply not fully blocking the focusing screen?
The mirror has a number of semi-transparent patches to allow light to reach the autofocus sensors, which are at the bottom of the mirror box (unlike the exposure sensors which are in the viewfinder side)
There is a flap (with also some mirrors on it) on the underside of the main mirror which folds when the mirror goes up and it covers the semi transparent parts but apparently it is not 100% effective.
That said, even if it were't for the semitransparent parts I think it is quite difficult to achieve a perfect light seal around the edges of the mirror without causing friction that would hinder the rapid movement of the mirror. I remember having the same problem a long long time ago with a Ricoh Kr-10, which didn't even have autofocus. However the problem only occured in extreme cases, shooting in bright sunlight with a piece of welding glass used as an affordable ND filter. I eventually figured out that it was light leaking past the mirror (there were no internet forums back then, or even computers) and started to cover the viewfinder with a hat - which seemed to work perfectly.
Nowadays with the K-30 I use a rear lens cap which seems to hook on very nicely to the viewfinder rubber cup, when I remember.
