09-04-2013, 07:30 PM   #1
tabl10s's Avatar
Bounced Fill-In Flash w/ Direct Sun.
How would such a photo turn out since the sun itself is harsh?
09-04-2013, 09:07 PM   #2
Can you give us some more info? How would you bounce the flash (I guess is it indoors or outdoors)?
It depends on how much power you use for fill (you could use just a little to take the edge off the shadows making things less harsh or you could use a lot and overpower the sun)
09-04-2013, 11:58 PM   #3
adwb's Avatar
I assume your reason for wanting to do this is to fill the dark shadow and to soften the hard edge of this dark shadow ?
The trick is to get the flash to supply 20-30% of the light in the image which will achieve that.
There are 3 ways to do that first by working out via the camera meter reading what each component is giving you, second by eye and changing fec and third using a flash meter that will tell you that ratio.
Will you be using a hot shoe mounted flash? If so turn the power down to -2 flash exposure and that will probably do the trick.
Or get the flash off the camera go fully manual ,
In either case there is no need to bounce the flash via a reflector.
09-05-2013, 12:09 AM   #4
ND8 filter so you can open up to f5.6 and be within x-sync. Flash may need to fire at almost full power.
camera, photography
Metz 58AF-2 Bounced Outdoors As Fill-In In Manual. tabl10s Flashes, Lighting, and Studio 0 07-29-2013 07:00 AM
Fill-in Flash muzee Pentax K-01 2 06-17-2013 05:51 PM
Bounced Flash: P-TTL, Auto or Manual? ElvisQ Pentax Q 11 05-23-2013 04:49 AM
Advice on fill-in flash RedSnapper Flashes, Lighting, and Studio 2 05-19-2011 12:25 PM
Slow flash - fill in flash - k100d soalle Pentax DSLR Discussion 4 06-21-2008 02:06 PM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
