Originally posted by stormtech Just for experimentation sake, I did this without disabling the focus with half press of the shutter button and it still worked fine. For me I like this even better as I can use either method. When I was holding the AF button and the lens was doing its thing, I half pressed the shutter button and it had no effect. So in so many words, the holding of the AF button overrides the half press shutter button AF even though I had not changed that in the menu.
So is there any other reason I should disable the half press AF? Am I missing something here?
Disabling the half-press AF is meant to enable you to use this setup for the focus-recompose method. If you don't disable the half-press AF, you'll be focused on whatever is under the focus point when you press the shutter button.
