I'm going to deviate from the advice above. first the suggestions to manually set the WB with the first 1 or 2 shots you take are good ones. The LCD is generally big enough to tell you what is working and what isn't. But the process is slow and cumbersome, especially if the light changes or you move to a new spot.
I recently took a weekend class that was all about lighting, WB and indoor shooting. From that I learned I was doing several things the hard way. Now there are a couple of things you can do for accurate WB in almost any lighting situation.
1) shoot in RAW whenever possible due to the better latitude for later corrections.
2) get a Studio coach
TheStudioCoach.com or some similar tool for manual WB setting.
3) shoot in matrix (multi pattern) metering.
4) carry a grey card to adjust exposure when needed and to later adjust WB errors.
So the process is as follows. Take the Studio Coach and set the camera on manual. Put the disk in a spot that will reflect the available light back at the camera. So if the light is coming through the windows with overhead lighting as well. Put the disk on the alter area so that the light from all sources hits the surface. Set the WB on the camera manually with the disk. Leave the camera in manual mode. If you want to shoot in other modes (Av etc) then that's fine but you'll have better control of the camera in manual, especially if you're shooting with a flash.
Now you can use the grey card for exposure adjustments if you want or simply use the meter to get the exposure values with the green button.
If you are taking portrait shots or other images that you're not certain the WB setting will work. then put the grey card somewhere in a corner of the image (to be cropped out later) and then you can make the adjustment you need in the software later. If your grey card is older than 18 months old, then toss it out. The dye's in the paper/cardboard will change colour over time. If you have one of the small 2x3" plastic clip on cards then it should hold the colour (if it's stored in a dark place) for several years and these are handy since you can clip it to something that will be in the scene.
If you want to manually set the WB with a simple white card, then make sure it's a true white card. they are cheap and much more consistent than a piece of paper or someone's shirt.
