Evening All,
A week ago today I was in Detroit. On the way to the airport, I took the opportunity to stop at
Detroit's Ford Piquette Avenue Plant which is the birthplace of the Model T, for a couple of hours. This plant is in the heart of Detroit - and is sometimes referred to as the lost and forgotten Ford factory. Its the original factory that Henry Ford built in 1904 to produce the later Model A's and ultimately the Model T - before the assembly line. I took my K5, tripod, head and several lenses. I posted here about it, in terms of looking for some additional information....
I went and shot cars. I pretty much had the run of the facility. The volunteer staff was absolutely helpful and wonderful - actually beyond wonderful.
My dilemma - I shoot almost exclusively in ambient low light - in the evenings, landscapes/cityscapes and architecture. I have shot indoors a fair amount, with very poor light, no flash and have done pretty well. I thought I knew what I was doing. I had shot the Roundhouse over at the Henry Ford's Greenfield Village, along with the Edison Generating Plant there. Both had poor light, and windows - that just overpowered everything else. I was able to handle these situations reasonably well using bracketing (+/-2ev with 5 frames). So, I essentially was expecting to be able to do a lot better than what I actually was able to do.
The windows in this building - are mostly original. One of the fascinations for me was the combination of the old original factory building and interior, coupled with the old cars, some of which were actually manufactured at this location (in this very building), and the light through those original windows. There are a few pictures of these cars at the Piquette Avenue Plant out on the web - but they all suffer from the blown out light from the windows. I figured I could actually do better. I wanted to capture the cars in the factory in the old original light - the entire environment.
So, I bracked everything (5 frames +/-2ev), with no bias, ISO 80 for the best dynamic range and image quality. I pretty much used my 12-24 exclusively and forgot to bring my CPF - which would just have added to the lack of light, but would have helped with some of the reflections.
For the last week, I have been post processing trying to get the windows to NOT be blown out. This has become much more difficult than I originally thought. I have even gone in search of information about old glass windows back in the early 1900's and came across some interesting information, that may explain at least part of the problem that is making this so difficult.
Upon getting home, last weekend - I loaded up the images and started stacking them using Oloeno's PhotoEngine - they actually turned out pretty good - but the windows were very blown out and had a lot of purple fringing. I then went from using all 5 frames to just the 3 underexposed frames (-4, -2 and 0 ev), and stacked them. Ever so slightly better. Then I took the -4 ev frame and experimented in shifting the exposure to about -5ev and used the four frames - and it really did not help things.
Then, I went into LR4 and processed all the individual RAW frames for CA/purple fringing - saved them as TIFFs, then re-stacked them in PhotoEngine. This did get rid of the CA/PF but the windows were still way blown out in almost all the cases. I also tried just going with only LR4 and that worked out even worse.
What I have found is that....
- The exterior light through the windows just overpowers everything, with a very sever case of back-lighting. I don't use any flash for fill, and that is a contributing factor.
- The cars are displayed on either side of a central aisle formed by supporting columns which divides the area in to bays. Essentially, standing in the aisle or in between the cars you can frame your shot, but you are always shooting into the windows in 99% of the cases. I went to the TPlex website (here and here) in order to link to it, and it struck me that the photographer who took their images - sidestepped the problem. The cars were rolled out into the center aisle away from the windows. By reducing/eliminating the back-lighting, then there is sufficient lighting to work normally. The Model A (the fancy red car) that I shot was in the center aisle and it came out very well.
- The original windows - If you look closely in the background, some of the individual windows panes are not blown out. These I believe are new (or more recent windows). The original windows of the day, were cut from large hand blown balls, and then laid flat to cool and be cut to size. I believe that this set up stresses so that when light comes through the window - it does so in a very opaque manner. The old glass varies in thickness and you can see the waves in the window pane. Modern glass is floated flat over a bed of molten liquid tin, so there is no stress in the glass, and thus the panes are clear and essentially transparent. A couple of the images do have the windows in a position where they are not blown out and you can actually see thorough them.
- I am finding that PhotoEngine does a better initial job than LR4, however - in order to try to reduce the blown out windows, I need keep the exposure down and that has a tendency to force the other adjustments up - thereby producing a somewhat over processed resulting image - it looks like an over-processed HDR image. That is what I was hoping to avoid.
I will say, that TPlex is a very challenging environment for photography.
The images below... Image #s
- The windows although opaque - I was able to mitigate the overblown effects somewhat. A CPL would have helped with the reflection on the front windshield.
- These windows did not turn out too bad. Not the best framing, and some bad reflections on the back side window.
- These windows turned out to be the best of all. However the central supporting column holding up the roof got in the way, and I did not frame it well at all.
- This shot turned out the best of all, and the windows were not blown out and you can actually see through them. This is the effect I was wanting to get everywhere.
- In this image you can see the new windows vs the old windows.
Does anyone have any post processing suggestions - other than to do a better job of shooting - especially composition next time?
