I know I will fail, but let me try nevertheless
-- To make a complicated story simple --
DoF (Depth of Field, in meters) depends on:
- FoV (Field of View, in degrees) and,
- Aperture (lens opening diameter, in mm,
not f-stops)
ONLY !
This
seems to be independent of pixel sizes (because is is based on the human eye's capabilities), sensor sizes, and so on.
But here comes one more bit to be understood:
For a given FoV and for a smaller sensor, you get a smaller focal length. Hence a smaller f-stop value for a given aperture in mm. And
ONLY because the smaller focal length lens with smaller f-stop value may not exist in the wide-angle market place, you end up with more DoF (and less light). Of course, you could have always got the same DoF from the larger sensor by making the aperture in mm as small as for the small sensor camera, i.e., by stopping down (and again less light).
Or to make it really short:
The available range for DoF for large sensors is a superset of the available range for DoF for a small sensor. (*)
(*) One more word... because based on amount of light, this already automatically takes larger pixel sites (same noise at higher ISO) into account, i.e., when stepping down with a larger sensor, you increase ISO too (same shutter speed).
