Hi,
As mentioned above, winter and snow present a variety of lighting and environmental conditions. Here are several things that I keep in mind.
- Exposure. If white snow fills more than about a third of the picture, the exposure must be compensated by at least +1 EV. Typically, my snowscapes are captured with a compensation of +1.5 EV. This is necessary because the camera's metering system assumes that a real scene averages to a mid-grey value, so it underexposes a bright white scene.
- Contrast. A field of fresh snow offers little contrast at mid-day (at mid latitudes). I find that early morning and late afternoon are the best time of day for shooting snow scenes, when the low sun casts shadows or presents reflections off of snow crystals.
- Lens hoods. Just as important in winter as in other times of year.
- White balance and colour correction. (a) Shadows in snow typcially have a blue cast. (b) Auto white balance may not necessarily handle a snow scene well, depending on time of day and the colour temperature. Take a reference shot of a white-balance card.
There are other important considerations not related to taking the picture:
- Environmental temperature. A system of mittens or gloves is critical. In coldest weather (e.g., minus 20 degrees C), I use fingerless mittens with a light inner liner glove. It's also important to dress well using layered clothing and warm boots (as in any other outdoor winter activity).
- Battery. Battery energy capacity drops significantly at cold temperatures, so the camera's battery will not power as many shots as at, say, plus 20's C. Take an extra battery and store it in an inner clothing pocket to keep it warm.
- Moving gear outdoors and back indoors. Sudden changes in temperature can cause condensation on camera and lens surfaces and on internal parts. It's best to seal the gear in plastic 'zip-loc' bags and let it aclimatize to the new environment. This is especially important when moving from the cold outdoors to a warm and moist indoor location.
- I have experienced few problems with shooting my Pentax K-5 in temperatures as low as about minus 20 C. It's rated to minus 10, but operates well below that limit.
- Sunglasses or goggles. Outdoor enthusiasts often wear polarized sunglasses. However, they will mask the rear LCD display of most cameras.
Hope this helps.
- Craig
Reason: technical correction.
