Originally posted by dms In view of some of the posts that either miss the point of using hyperfocal distance, or suggest methods that take a moment or two, I would say the following.
Whether street photography or landscape, there is the element of time. For this alone the concept is useful. Grab the shot at the hyperfocal distance! In another few seconds the light may change, the person may move, and so on.
Once the shot is taken one can spend time trying to improve on it. But if it's a scene with equal import from far to near, likely the hyperfocal distance may be best anyway.
Well, for example is the M43 camera with a standard-to wide lens of 15mm . Here the hyperfocal is 3.77 metre. I suggest if you are doing a landscape with wide angle per bscott's op, you would be better not to blindly follow the hyperfocal.
It might be a sharper focus overall to use distance judgement and screw the focus towards 10 ~ 20 ~ 50 .. or infinity,
Try a few photos with various focus points on the scale , one test is worth a thousand learned opinions!
