I do most of my shooting within 30 minutes of the sun being on the horizon (mostly sunrises), so I frequently deal with the challenge of exposing for the image. I first decide what I am showcasing: if the beautiful sky colors, then I don't mind underexposing the foreground and going with a silhouette approach in order to maintain sky saturation without blowing out too much.
single exposure single exposure with intentionally overexposed sun
If the foreground is my main subject, then I will often do a 2 or 3-exposure bracket and then either manually blend sky with ground using layer masks, OR, I will do an HDR or a partial HDR.
manual blend of 2 exposures partial HDR using 3-exposures manual blend of 2-exposures
Like many, I used to hear the word HDR and gag because the only HDRs I seemed to recognize were those over baked grunge looking things using one of the preset settings. Now, I have a greater respect for the value of HDR and selective HDR for enhancing the image, and preserving some (not ALL) dynamic range.
these two examples are on the strong side for my taste but I still feel appropriate to retain detail and otherwise lost shadows/highlights:
full HDR (2-exposures) full HDR under intense light (3-exposures)
When I want the sun to be present in the exposure, I count on a certain amount of overexposure, as it would be a little unnatural not to let the sun blow out at least a bit. If I am shooting before the sun breaks the horizon, I like to spot meter on the brightest part of the sky to prevent overexposure, and add 1.7 to 2 stops of +EV for the second shot in order to grab the foreground. This usually gets me where I want to be. If the DR is much beyond that, I may capture 3 bracketed exposures.
Though I recognize the value of ND grads in many situations and respect those who use them religiously, I personally find them less refined for my needs than I'd like. The example of the tree or mountain or bridge sticking up in the horizon that becomes blackened due to the filter is enough for me to avoid this look. They also introduce another possibility for contrast-reducing flare when aimed at the sun, and that is the primary reason I would be using them.
