If your tripod is not heavy enough, hook something heavy on it - like your bag/backpack.
A lot of the new carbon tripods (and aluminium ones) have a hook under where you can pull it down and put your backpack to add more weight to it if needed.
But, if you are moving from place to place a bellow and tripod might not be the best thing to do.
There are too big and very heavy to move around. Bellows are good for static, in studio environment.
For outdoors, you are better off in building some sort of rig where you can bring your flash light next to the front of your macro lens. This way you have a lot of light that you bring on your subject and you can shoot at higher shutter speeds. Focus by moving the camera rather than the focus ring.
For higher magnification when out in the field, you might want to invest in...
- either 1 macro reverse ring that will allow you to mount a 50mm, 35mm lens at the end of your macro lens in reverse - inexpensive
- or a set of macro extensions tubes - will work just like a bellow - inexpensive as well
