Originally posted by adwb I have never found a use for the optical preview and on my bodies it certainly does not set the exposure as does the green button.
Well, in some circumstances, optical DOF preview can be very useful - that's why they had it on many film cameras.
It's especially handy with fast lenses, where the DOF you see in the viewfinder is extremely shallow. There could be something awkward behind your subject
that you won't see until the lens is stopped down. I don't use it nearly as often as i should in my own work, but when you're shooting macro,
a shot is easily spoiled by a badly placed twig in the background ( or even in the foreground! ).
When you've got your once-in-a-lifetime shot lined up, you can do a quick DOF preview to check that there isn't something awkward in the background
and if there is, you can shift your shooting position ever so slightly to get the background you want. Having that function on the on/off switch ( as it was on my K200D) puts
it where you can easily access it since your index finger is already on the shutter button. And yes, there are circumstances where chimping might not be an option,
and you have to get your shot without taking your eye from the viewfinder.
With my K-30, I have to use the Raw/Fx button, which I find awkward - I find myself having to search for it ( maybe I'll get used to it eventually ).
That's one standard application for (optical) DOF preview. It's not specific to older K mount lenses. There are probably other uses I'm not thinking of right now.
Like I said, DOF preview was a standard feature on film bodies. Photographers used it. I used it.
By keeping the meter active during DOF preview ( on some digital bodies ), Pentax provided us with a bonus feature: you could use it to do metering with older K mount lenses.
It doesn't set the exposure, which is fine, since we might not want to change the exposure, and the green button does that in any case.
This is another option - just metering, for when you want to check the exposure without altering it. I was disappointed to lose that feature on my K-30,
even though I don't shoot with older K-mount lenses very often. If I was still using my M series macro lens, I would have been royally pissed.
It's unlikely that it would have cost Pentax anything to keep the meter active during DOF preview on the K30. Perhaps they could fix this with a firmware update.
Maybe I should upgrade the firmware to see if they already have.
