The stuff in focus is in a plane (roughly). In the burger picture, they keep the front of the burger in that plane by being close to 'eye-level' with it (so it's parallel with the sensor), and also arranging the front of the fries to be in the same plane. Note you have most of the front of the cake in focus in your f/2.2 picture, if you'd moved the camera down a little more you could get all of it. I've attached a little graphic, imagine the frog and the bug are food (and they will be to some people or snakes). By rearranging your subjects, you can get more in focus and still use a wide aperture to get an out of focus background.
Controlling the distance to the background will also go a long way here, and can let you stop down a little more to get more of the food in focus and also use your lens where it's sharpest (definitely stay above f/2.0 with the FA50/1.4 if you want any hope of hitting 'scary sharp').
Don't be shy about taking a few pictures with the same settings but moving the focus point slightly, with such a narrow DoF you're after it's tough to hit it dead on until you've had tons of practice. I wish 'focus bracketing' was a standard feature! A tripod is also preferable here.
The lighting is also pretty important for the look in the burger shot. Try window light from behind with reflectors placed around the front to brighten it up. Yours also look a little underexposed, the plate looks like it should be white but it looks too grey.
Best of luck
