Originally posted by 8540tomg In particular I would like to know if the spotmeter is more accurate than using the green button?
Different is the word.
The stop-down (green button) metering should be essentially accurate* with your K-5 in M mode and much less so with your K10D. Neither camera will meter reliably with M42 glass in Av mode. If you are unhappy with your results an external meter may be a good option.
That being said, let's get back to the spot meter. Here are a few discussion points as applied to a spot meter vs. hand-held vs. TTL meters:
- Spot meters are not magic
- Spot meters are not better per se, and when used improperly may actually result in badly exposed shots
- The spot meter is a specialized tool that is used to measure reflected light values from a specific portion of the subject, though care should be taken to remember that the reading will result in a middle value on the final image
- A spot meter, when properly used can allow for fine control when placing the original exposure with the intent for massaging the image later in processing
- A regular hand-held meter may be used in a manner similar to a spot meter if you are able to take readings close in on the subject
- The above point also applies to the in-camera meter
- The in-camera TTL meter has the advantage of automatic compensation for light absorption by the lens glass and any filters
- All three are essentially accurate in that they can be used to determine an appropriate exposure
There is at least one user on this site (Tuco) who is a regular spot meter user. He uses it primarily for his medium and large format film photography.
Originally posted by 8540tomg Is it quicker to use than the green button?
ROFL
No...
* Accurate in the sense that metering off an evenly lit, neutral target (say a blank inside wall) will result in equivalent mid-range value distributions in the histogram at all apertures with all lenses.
(...almost never uses the spot meter feature on the camera's that have it...)
