Originally posted by Zilla I'm trying to learn how to shoot multiple images to combine them into one pano using PS CS3's stitching tool. One advice I keep reading is to of course keep the exposure consistent between the shots. Make sense correct? I'm trying to do this via the following method...
- Use hyper-M mode
- Use the green button to set the exposure (whether correct exposure or not is irrelevant
for now)
- Use the AE-L button to lock the exposure
- Start taking my shots in portrait mode from left to right, overlapping by 25%
However, after the 5th or 6th shot the AE-L unlocks! Why? How can I keep it locked for the whole duration? I set my metering time set to 30s. Thanks!
Firstly, use Manual or M mode and set the exposure for the brightest part of the scene and keep that exposure for all shots.
Secondly, it is also best to use manual WB so as to set it the same for all if you are shooting in jpeg. You do not have to use manual WB in RAW, as it can be tweaked in post process, but it still makes it easier if you do.
Thirdly, if you can afford it, I would recommend PTGui photostitching software. It is by far the easiest and most successful I have used. See some of my examples here:
Panoramas Photo Gallery by Lance Blackburn at pbase.com
I have printed two of the Bondi panoramas and one of Sydney Harbour using my Epson R2400 printer on rolls media and have mounted them on my wall. The two Bondi Panoramas were printed to 1,880mm long by 330mm high. Unfortunately I had to cut them down to 1500mm x 330mm as they couldn't get a surround bigger than 1600mm wide. The photostitching software is that good that you *cannot* see any problems with these photos. They look as though they were taken with a large format camera.
I cannot recommend PTGui highly enough.
