Originally posted by julez113@yahoo.com Hi all,
I am new to this site, but not new to Pentax. I've been shooting with an istDL for 3 years and have now upgraded to a K20D, which is technically much more advanced than I am. I want to enter a photo contest (deadline TODAY) where they require my photographs to be a minimum of 300 dpi with a total file size between 12-17 MB. When I set my K20D to 14.6 at the highest JPEG quality, my images are only 72 dpi x 72 dpi and 6 MB. I know I am technically challenged, but can someone please tell me how to achieve this image quality (300 dpi/12+MB) with the K20D? Thanks,
Julie
aka technically challenged
Send them a TIFF
.... Anyways I THINK they got it wrong as to MB vs MP. I THINK they meant 12-17 MP at 300 dpi.....
File sizes will depend on soooo many factors that it is really not that important.
As to the 300dpi, as mentioned, it is only a marker.
3 things to note on this image: W a 6MP camera at 300 dpi it would print at 10.1 x 6.7 inches vs 100 dpi which would print at 30.38 x 20.22 inches...
NOTE the "Maintain original size" check box. This is important and only means that I have NOT resampled and altered my data. The ONLY thing it did is bascially make the "dots" bigger....
Bigger dots bigger image...NOTE file size has not changed (this is a 16bit TIFF so file is huge compared to a jpg 36.8MB)
As to why I believe they meant MP instead of MB is because IF you want to enlarge the image to 30.38 X 20.22 AND have it 300dpi you must ADD dots (3x more dots BTW), which will be created in some manner. This completely changes the picture and data...
So I believe thay just want more "dots" (i.e. MP) so as not to have to create as many "new" dots from the old.
To create a 34x28 image from a 6MP camera would involve tripeling (or so) your orig dot count (they would be created by interpolation using 1 of many types of formulas).. At 12-17 MP you would only need to double and this would maintain quality. Actually they would probably print at 150dpi and then not have to "upsample" much if at all .
Lower MP count and you have to change the actual image.
ADDENDUM for print size comparisons:
12mp image at 4000×3000 pixels would make a:
13.3” x 10” print at 300dpi
20” x 15” print at 200dpi
25” x 18.7 print at 160dpi.
26.6" X 20" print at 150dpi
39.9" X 30" print at 100dpi
