05-04-2008, 11:13 AM   #1
Focusing issue?
I am new to the d-slr thing and have had my K10d only since Feburary but I have been struggling from the beginning to get a good sharp photo. There were two things I have been looking at which are user error and the known fact that the K10d needs PP or custom setting +2 sharpness 1+ contrast. But I still don't get the truely sharp pictures I know this camera is capable of.
I do a lot of manual focus ( one of the reason I thought it was user error ) macro/closefocus but the Tamron 90 2.5 doesn't put out the photos I know it can. I know it takes a lot of practice which I do but still..... I have tried tripod, self timer and other lenses with autofocus and let the camera do all the work.
Some of the pictures look fine when I first download but as soon as I try to zoom I loose detail fast. Even after PP I have very little detail. I have been thinking all along it was that the pictures were just soft but I am beginning to think it is a focusing issue.
What is a really good way to test the focus and how to tell the difference between soft and out of focus?
Thank all, Oren
05-04-2008, 11:15 AM   #2
MJB DIGITAL's Avatar
is it possible to post a couple?
when you zoom it to check the detail, how much are you zooming?
i dont really run camera tests but im sure someone here will tell you about some chart tests or newspaper tests.....
good luck
05-04-2008, 11:31 AM   #3
QuoteOriginally posted by MJB DIGITAL Quote
good luck
If you do post photos, please add exif info (shutter speed, ISO, aperture, etc) and the type of lens you are shooting?
- Bert
05-04-2008, 11:34 AM   #4
http://http://www.flickr.com/photos/33427578@N00/
I did a lens test a little will back but these are a few of the better ones.
05-04-2008, 11:38 AM   #5
QuoteOriginally posted by OrenMc Quote
Unfortnatly the maximum resolution on your flickr site is only 800x558 pixels.
Judging from this I don't see what is wrong.
Nice Seattle photos by night though.
- Bert
05-04-2008, 01:17 PM   #6
Here is a shot today. I had it on a tripod. Quanatary 70-300 ( not the best lens I know but ) Green mode @ F 4.5 1/4 sec ISO 100 I also kow I probably should have raised my ISO to increase shutter speed but I did have it on a tripod.
05-04-2008, 01:25 PM   #7
Do you shoot in AV mode?
Watch your shutter speed. You shot this at 1/4 sec @ 180mm. SR is good, but not THAT good. . The rule of thumb for shutter speed with out stabilization is 1/ the focal length x crop factor, or in your case 1/(180x1.5) , or 1/270 sec. If you are really steady and have a subject that is standing still, you can get 2-3 additional stops, or about 1/60 sec. If you have a subject in motion, you need a higher shutter speed.
Learn to balance your shutter speed to aperture to ISO speed, and you will find yourself doing much better.
05-04-2008, 05:25 PM   #8
i would guess that you have some camera shake going on, but of course, that is just a guess.
another possibility could be that your blur is an effect of having SR activated while on a tripod, but I dont know if you had it on or not.
and yes, get your shutter speed up. a quarter of a second wont do for anything really unless everything in the frame is stationary or you are doing something (art) that wants to be shot at that speed.
mitch
05-04-2008, 06:29 PM   #9
Ole
Ole's Avatar
Use a smaller aperture. If f/4.5 is near or at the max for the lens it won't be at its best.
Use the 3 seconds selftimer when you're on a tripod. That does two things: Turns off SR if you should have forgotten to(you don't need SR on a tripod) and flips the mirror up 3 seconds before exposure thus eliminating unsharpness from the mirror slap.
Try another lens.
05-04-2008, 06:48 PM   #10
The bird would have moved during a 1/4 second shutter speed, so this isn't a fair test
05-04-2008, 06:56 PM   #11
QuoteOriginally posted by little laker Quote
but then the post the bird was perched on would have been in focus if the bird had moved
05-04-2008, 07:01 PM   #12
If he focused on the post
05-05-2008, 05:42 AM   #13
No this isn't a good example of what I am having issuses with. This one is SR, but thanks for the help. I'll try another one this evening.
05-05-2008, 07:14 AM   #14
OrenMc, I've seen several people using plastic toys as models. And they're almost the perfect subject.
They don't move, and have nice sharp edges to start with.
Stuffed animals just have too much fir for an accurate assessment.
05-06-2008, 05:24 AM   #15
Good idea little laker, I'll give it a whurl.
camera, detail, error, focus, k10d, lot, photography, pictures, pp, user
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
An expensive way to find that your camera has a focusing issue sterretje Photographic Technique 0 01-06-2010 10:01 AM
Back focusing AF lens an issue on MF film bodies? RichyX Pentax Film SLR Discussion 6 11-11-2009 01:38 PM
Front-back focusing issue Mystic Pentax DSLR Discussion 10 08-26-2009 08:15 PM
Tamron 28-75mm f/2.8 Focusing Issue Scout Pro Pentax SLR Lens Discussion 3 04-15-2008 07:46 PM
All times are GMT -7. The time now is 08:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
