Originally posted by Imageman This issue of taking landscape images with all areas in focus can only be resolved with a field camera with movements that can tilt the plane of focus.
I understand what you are wanting to say. A view camera, of which field camera is a type, may often be used for near-far focus with good success. There are limits however, as well as side-effects, but if you want near-far a camera with the right movements can help make it possible.
That being said the camera doesn't actually tilt the plane of focus
per se. That remains parallel to the lens plane for a subject plane that is also parallel (the normal case). What it does allow is placement of the lens plane at an angle to the subject plane with placement of the image plane complementary to the subject plane. It is hard to explain in a few words, but actually fairly easy in practice. The side-effects include possible distortion of perspective. The reader can Google "Scheimpflug" for enough detail to make your head hurt.
With digital images, the problem may be approachable with a narrow aperture and image stacking. As for wide angles and DOF...For a given degree of magnification and absolute aperture the DOF is the same as for any other lens. The apparent near-far sharpness of a wide angle is due to low magnification and comes at the price of everything in the background being tiny, tiny, tiny in a near-far scenario.
