Sany, at this point, this will be your best resource:
Strobist
And a great book:
Light Science and Magic: An Introduction to Photographic Lighting: Fil Hunter, Steven Biver, Paul Fuqua: 9780240812250: Amazon.com: Books Originally posted by sany @carrrlangas - your words '1/180 is plenty for most uses' is a real comfort as I am reading the other comments and inablity of Yongnuo YN-560 III to do this. Does this mean, that I can still freeze 'rain' shots like the ones you must have seen - night shots in rain and flash going from inside the umbrella where we see those rain drops freeze!? I am looking to play those kind of creative shots....
The strobist will be a treat to understand this but IŽll try: Yes, I think 1/180 would freeze rain but, the
short duration of the flash (much less than 1/180, I think itŽs something like 1/1000 to 1/2000) will freeze it too. So you can use a slower shutter speed (1/40 for example) to get some ambient light captured and use the flash to accentuate the rain drops or else. So you would be mixing ambient light with flash light relying on the short duration of the flash to freeze the action and using a slow shutter speed to capture the rest of the scene..
Originally posted by sany 1. Can you also elaborate more on your last line 'If you use a compact camera with flash and the optical slave mode on the yongnuo youŽll can sync at the max shutter speed of your camera, really fun.' yes, I am looking for those kind of fun stuff.
Compact cameras has another type of shutter mechanism that allows much faster sync speeds than DSLRs. So you can use the pop up flash on the compact to trigger the Yongnuo flash: See the button between "MODE" and "ZOOM"?, it selects how the flash will be triggered.Press it until you see "S1" on the top row of the LCD. I think it stands for "Slave mode 1" and youŽll see a red light flashing on the front of the flash. So, when your compact cameras pop up flash fires, the Yongnuo flash will "see" it and fire itself.
Originally posted by sany 2. How do I make the compact camera trigger and sync with my dslr to achieve that if my understanding is what you mentioned!?
As explained in other posts, you canŽt trigger your DSLR at high shutter speeds... I meant you will be able to sync at the max shutter speed of your compact camera because they usually sync with their pop up flash at any shutter speed.
Have fun!
