Originally posted by Dewman Not to belabor the subject, but if I understand this correctly, I could get a tube extender and accomplish the same as the lens reversal, right? Which would be better, in your opinion, keeping in mind that I'm a true newbee in the field of macro photography. I read that one could also remove the glass from a tele-converter and it would serve as a tube extension. Would I be correct in assuming that "more is better," meaning that the longer the tube, the better, within reasonable limits, of course?
There's a guideline that for 1:1 (magnification) and below, use the lens mounted normally with extension. For higher magnifications, reverse the lens and use extension.
Best approach depends on what lenses you already own and what magnifications you're interested in. Lens reversal is a great technique but it's not the most user-friendly: the working distance is small, making lighting tricky (you can easily shadow the subject with the lens), and you lose open-aperture metering (if you stop down the lens much the viewfinder becomes very dark). Also, high-magnification work is tricky for various other reasons.
Still, if you already have one or more lenses with aperture ring, experimenting with extension, reversal, and lens stacking is a fairly cheap way to start. If, however, all your lenses are DA (no aperture ring), you might want to try a Raynox (supplemental lens).
