Originally posted by Hornet Auto in this case only means that the aperture will stop down when the shutter is pressed. It does not mean that you will have control of the aperture via the camera body. This means that you can only use a lens with an aperture ring (and not on the A setting).
The only truly auto tube set I have seen is made by Kenko and will run you about $200+ used. The other option is to take the glass out of a true auto teleconverter.
Thanks, Hornet. This is the kind of response that tells me what I need to know.
Dewman
SW Idaho
