Reverse lens ...
Ok here is a sticking point :
I will address this here and now :
You lose aperture when reversing a lens , a lot like using a M42 lens ...
I dont like M42 lenses , so that means I would most likely not like using a reversed lens , except perhaps for lens stacking ...
Lens stacking is where you reverse a lens in front of another lens ..
This way you still have aperture control , and the added magnification of a reversed lens ..
Back to using a reversed lens :
You have to open the aperture to get your focus , then close the aperture for the photo ( DOF ) , and all your settings need to be correct , as does the focus ...
This is laborious , slow , and probably only suitable for studio work , otherwise you have to pick a aperture setting and live with it ... ( limiting )
What would be better = Macro tubes ... With aperture levers .. Or even a Tele Macro Adapter ...
Anyhow , there is no wrong way , but I dare say a reversed lens is doing it a little harder , so a much greater learning curve .
---------- Post added 09-10-14 at 12:27 AM ----------
Originally posted by Wild Mark Great initiative.
I am a beginner but have jumped into the deep end without hesitation (not baby steps - too much time to lose). So a guide to better macro photography would be awesome.
As indicated I have jumped in deep, but still have a way to go. I have not spared a dollar in my investment, but must admit am growing frustrated with the returns. Things that frustrate me are lighting, camera setup and tripod usage. Ultimately the results I get make me question my gear, but surely I shouldn't (A*200 macro plus other lenses such and Bokina on K5 ....) but perhaps I should??? For example, the attached image taken on a tripod in controlled conditions took 20 shots to perfect. I should be able to do it in one shot .... sooooo the question I have is 'how do I test my gear to make sure my results are technique and not some other factor beyond my immediate control?'
F10 - 1/250 - ISO400
200mm Lens ?
Anyhow , looking at the image .. I would trade some shutter speed for a higher F-stop ...
Or I would back off some ( be further away ) , this will increase DOF ..
Since your using a K5 , you can crop the image some to get that closer look .
Software :
I have tried a few , and I keep coming back to PhotoScape .. I only use a few functions when PP , and PhotoScape covers those functions well .
If you want to photoshop , or maybe GIMP , they do require more dedicated learning ( mastering the software ) , and Im too lazy to photoshop or GIMP .
One day perhaps , I have used GIMP a few times , but it does not do a better job of PP for my needs , so I keep using PhotoScape .
Perhaps one day my needs may outgrow PhotoScape , till then .
I have an old photoshop somewhere , maybe I should play with it some more ? ( Thing is , I don't need such powerful software )
---------- Post added 09-10-14 at 12:30 AM ----------
Originally posted by Wild Mark And knowing how to post process efficiently and well is another thing I want to better understand. The second photo is posted simply to show how I am struggling with colours etc (upload always looks bland compared to what is on my screen).
What software are you using ? Chances are there will be several tutorials on youtube ...
