To delve deeper into the world of tiny big I just got me an extension tube set. As I'm planning to add the Pentax 100mm macro later on I dished out some extra cash to get me, as I thought, quality ones with aperture control and electronic contacts (no AF).
My first issue is, that neither the Pentax 35mm f2.4 nor the 50mm f1.8 would fit onto it. They just wouldn't screw all the way and, of course, I didn't want to force it. Interestingly my 18-135mm mounts without trouble. Possibly something to do with the plastic mount? First setback, but I could accept that.
But the real problem is, that it would cause my display/menu/camera to go haywire. EV scale jumping around, AF metering (which was turned off as I put it into MF anyways) twitching between spot meter and something else. And when trying to access Info or Menu to adjust settings it would go there for a split second only to jump back into the main display again.
Not stacking the tubes and using only one would better the situation but not eliminate the problems.
Are the tubes (contacts) faulty? Is the K3's current too low so it won't pass through the tube bridge? Is this a known problem? Could that even short circuit my camera? I am rather at a loss and hope you can give me some insight. I'd like to have aperture control tubes as the Pentax macro doesn't, and those were the only ones I could find. But, like this, I guess the tubes are pretty much unusable and I should return them quickly.
