Originally posted by jatrax I'm not good enough to tell you why. But if I was taking a picture there I would have been either 10 - 20 feet to the right or maybe even the left. But just not there. You are correct, there is something wrong with that shot. I think the central horizon is part of it, cover up the top 1/4 of the image and take a look, it is better.
Thanks for help. You are right, just moving the horizon helps. I think there is something about the place where the sight converges in this shot. I think it is too close to the center. I am always having trouble with shots like this - when there is a road, or some lines that converge from the corner, to the center.
---------- Post added 09-19-14 at 08:16 PM ----------
I cropped out the sky, made it wider by changing aspect ratio, photoshopped out the central part of the road, such that the road leads to a point on the crossection of golden rule division lines. Then I put the hay on the left crossection.
I think that using a very wide angle lens and cropping top and bottom might be the best bet in cases like this.
This is what I mean (I am not going to post a shot that belongs to someone else, so this is the closest thing).
