Sorry, but that is sort of a silly question. FOV is measured in degrees of arc.
But, in the interest of being helpful, all you need to do is to calculate the "crop factor" for your final crop. In simplest terms that is the length of the
diagonal of a 35mm FF frame to that of your cropped frame. The total pixel count is incidental. What you need to know are the pixel dimensions and frame dimensions for the sensor. This varies by sensor, even within Pentax.*
crop factor = FF diagonal length/final crop diagonal length
"Length" is some unit of linear measurement. This is not the same as the number of pixels. The original "crop factor" is not part of the calculation unless you want to complicate things. You end up running the same numbers twice.
To speed things along:
- The diagonal length of the 35mm frame is
29.4mm 43.3mm. - The frame dimensions for the camera are in the camera's specifications. This varies between cameras. For the K-50, the diagonal is
19.3mm 28.4mm. - The pixel dimensions of the original frame are whatever came out of the camera.
- The pixel dimensions of the final cropped frame are whatever they are. You use this to calculate the height and width (on the sensor) of your final crop. The number of megapickles is incidental.
Remember that it was assumed that the ratio of the final crop is still 3:2. If your aspect ratio changes, the FOV comparison is less valid.
As mentioned above, the number of pixels in the crop is incidental and a red herring. To do the actual calculation, Pythagoras is your friend. Remember that the linear measurement is the basis for your calculation, not the number of pixels.**
* The oft quoted 1.5x crop factor for Pentax is an estimate. The actual crop factor is 1.53 or 1.52 depending on model.
** FWIW, what is described above is essentially the same type of calculation used for figuring the actual lp/mm resolution for lens testing using a standardized target.
