Originally posted by stormtech Thanks for sharing your macro gear! I'm kind of moving away from wildlife shooting due to physical limitations and moving toward more macro work. I have a good start on the gear I need already - just need one of those circular flash mounts. I have 2 Pentax AF200T flashes that I am going to use along with Cactus wireless triggers. I have a lot of experimenting to do setting up the flashes. Over the winter it will be all still life type macro work so I won't need portability.
Which begs my next question - I don't see you listing any tripods or other gear like that. Do you do all your work hand held? I absolutely have to use a tripod, and also am looking at a decent macro focusing rail.
All hand held :
I tried the tripod , uh my G** what a load ! , for my photography the tripod is a massive hindrance , monumentally huge hindrance ! ( Leave home without it )
I also tried a monopod , almost as bad as the tripod ..
You hardly ever get the perfect shot where you have time or space to set up a tripod . Or I should say , " I hardly ever get the perfect shot "
So my cameras are set up for hand held ..
