Originally posted by gifthorse Has anyone used the MJKZZ-LTRIG-C3 on the K-5ii?
As far as I can tell, the pentax plug wiring is identical to the canon "consumer" grade cameras (rebel series, 60d, and other mid to low end) - I have a whole pile of wired 2.5mm remotes made for canon and every one of them works on my K-50. Note that the sellers part number that
MJKZZ-LTRIG-C3 ends in "C3" which means that it comes with the canon N3 connector which is not compatible. If you ask him to, he said he would substitute a 2.5mm cable upon request. You must ask, otherwise you will not get the right cable.
