Originally posted by flaviopetrone I tried to say something similar yesterday, but I don't have all these knowledge like you. Thank you.
That's what I did. I drilled a 1/4" hole in the cap then punched a hole with a needle in a piece of aluminum cut from an aluminum beverage can and glued it to the inside of the cap, over the larger hole. I measured the needle at .032" but I'm thinking it should be more like ,025 - .028. I'll give it another try when I get a little time.
I was way off. I went back to the calculator and found that the hole should be .29mm, or .011in. That explains the extreme out of focus image.
