Originally posted by Hattifnatt Monopod with cable release, now that's an interesting idea! I suppose you hold the monopod with one hand and release with the other hand? anyway, I did not think of doing this before.
I'm sometimes using my tripod as a monopod, not sure if it's a great idea though.
I try to describe my way in total.
Build a tripod with your body and the monopod. The fixing points:
The bottom of monopod (1st point), ball head with camera leaning towards your head, left foot (2nd point) and right foot (3rd point) in step position at shoulder’s width.
1-2-3 is your "body tripod"
My monopod has a strap at the grip as you find it at a ski pole. With my left hand I slip through the strap. Holding the grip of the tripod I slightly pull downwards so that the strap gets tension. The effect is that the camera is pressed against my forehead when I look through the viewfinder.
The right hand is free to operate the autofocus button of the camera while holding the cable release. What’s next? Supposed everything is set to take the photograph, you can move the palm of your right hand to the left side of the camera to get even more stability.The button of the cable release now waits for your right thumb to pull the trigger.
I think this sounds complicated. I took an image to show it:
