Originally posted by OrenMc I have a Slik tripod which is light weight and really not heavy enough for the lenses I use. What I was wondering how a good stout monopod would work for the K10D + tele lens. While watching my tripod I could see the vibration. I am looking at monopods because I do some backpacking. Does a monopod take care of the vibration very well? Thanks all.
There are several issues with vibration, first is vibration of teh entire tripod assembly, although more expensive tripods are better at this, virtually every pro recommends suspending a weight from the tripod to take the bulk ov these vibrations away. Many carry specifically made bags they fill with rocks. I usually suspend the remainder of my kit in my camera bag.
There is also vibration about the tripod head, which suspending a weight does nothing for. Some of this can be eliminated with different types of heads, but for really long lenses the best is a long lens support. see the attached link
Bogen / Manfrotto | 3252 Long Lens Support | 3252 | B&H Photo
This works really well, and note that although shown vertically up from a tripod leg, I find that an angle (side to side) works better because vertical orientation only removes vertical vibration, where as a sideways offset helps take both vertical and horizontal vibration away. Note the camera can make some of this with the mirror and shutter movement
ALso use a cable release.
Monopods work well and are mobile, but a tripod is the ultimate. Even with a monopod, you will have some motion, and you might want to consider even with the monopod, using a cable release to isolate the camera from unintended motion when pressing the shutter/
