Originally posted by bladerunner6 I want to focus on bugs but I will do other stuff.
Should I buy a couple or just one set?
Thanks.
Hi....
Personally i know 3 ways for macro photography without spending more
[1] recommend Close up lens where you are having all the controls in your hand in manual mode and good result also then [2]extension tube(Passive)....If the Extension tube is active one means more setting you are able to do while capturing then its better one.
I am using Close up lens 10 + for getting optimum level that is also the basic one close up lens. 20+ is spoiling images...stacking of more than one closing lens also detoriarating quality....
[3]3rd option is Reverse Ring Adapter that may be used when full light is available and manually you have to maintain focus
Finally if you want to bear some cost/expense then go for Macro lens + quality close up lens.
Have a great shots ahead !!!
