05-26-2008, 08:17 AM   #1
neutral density filter in Photoshop?
Hi,
I know that in Photoshop there's a way to simulate the effect of a "graduated" neutral density filter. But is there a way in Photoshop to simulate the effect of a regular neutral density filter, for instance to create that "artistic blurred cascade of water" from a waterfall?
Let me rephrase that. I'm sure there IS a way, if you were painstaking enough with pixels, to do just about anything in Photoshop. But is there a relatively SIMPLE way, like with the graduated filter?
Thanks
Dave
05-26-2008, 08:38 AM   #2
What you probably don't want: fill a layer with a mid gray (no gradient) and set to "multiply" mode. Adjust opacity as desired. Now you have less "light" for the whole scene (what an ND filter does).
To add motion blur to waterfalls, etc. (where ND filter allows to a slower shutter speed for a given exposure), try the Motion Blur Filter. You will have mask out the areas you don't want blurred. Conceptually, not hard, but making a good mask can be a lot of work.
-Mark
05-26-2008, 04:10 PM   #3
Wheatfield's Avatar
There is no simple way. This is still best done in camera.
05-26-2008, 07:27 PM   #4
What Wheatfield said. Still, it is astonishing what the motion blur filter can do if you use it carefully.
camera, density, density filter, effect, filter, photography, photoshop
Neutral Density Filter FAQ Donkeypunch Pentax Camera and Field Accessories 40 03-05-2011 09:23 PM
Neutral density filter desertwalker Troubleshooting and Beginner Help 5 01-04-2010 04:58 PM
How to use 1000x Neutral Density filter with DSLR Thule Pentax DSLR Discussion 23 07-11-2008 05:30 AM
Graduated Neutral Density Filter Options sharko Pentax SLR Lens Discussion 5 06-25-2008 02:19 PM
For Sale - Sold: FS: Neutral Density Filter plus others 52mm Bob Tuttle Sold Items 1 05-23-2007 11:34 AM
All times are GMT -7. The time now is 03:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
