Originally posted by r0ckstarr How would the Venus do when compared to the 100WR? The 100WR is 1:1, and the Venus is 1:2. Reproduction ratio vs. focal length is what I do not understand. Does the extra focal length of the 100WR make up for the difference between the two, or would cropping with 100WR to achieve the similar results? Or, does the Venus magnify more at 60mm than the 100WR does at 100mm? If you had/have the 100WR, would you still consider the Venus?
The magnification ratio is
(size of image projected on sensor) :
(size of object in real life) or written as a single number (size of image projected on sensor)/(size of object in real life)
The Venus projects an image twice it's real life size, so it's 2:1 also written as 2.0x. The DFA100 can project a life sized image so it's 1:1 (also written 1.0x), and so are the other current pentax macros, da35/2.8 and the dfa50/2.8. Some of the older film-era macros can only project an object at half it's life size
Super-Multi-Coated MACRO-TAKUMAR 100mm F4 and it's 1:2 (also written 0.5x).
With the DFA100mm (or other modern macro), you can fill the frame with an object the same size as the sensor, or roughly 16mm x 24mm. What changes between focal lengths is the minimum focusing distance you have to be at to get this magnification- the DFA100mm hits 1:1 at 30cm, the DFA50mm hits 1:1 at 19.5cm and the DA35mm hits 1:1 at 14cm (almost touching the front of the lens- these focusing distances are sensor to object). It can get complicated as the focal length of some lenses actually change as you turn the focusing ring and their guts move around (here's a neat animation of a nikon 85mm macro that drops down to 71mm at min. focus distance:
Short Presentations, by Pierre Toscani).
With the Venus on a Pentax APS-C, you'd be able to 'fill the frame' with an object measuring 8mm by 12mm. With the older macro I linked to, the max is an object 32 mm x 48mm. The Venus wins for super small stuff, especially if you don't want to crop.
Whether it's worth it for DFA100mm owners or not is another question. For me, not so much. For the times I want to get more than the DFA100mm I can add a 1.4 teleconvertor or extension tubes (or both) or I can pull out reverse lens options which are probably in-between the DFA100mm and the Venus for convenience, but are cheap and can provide way more magnification than the Venus alone. For me, it doesn't add enough convenience over lens reversal or enough magnification over the DFA100 (+ TC) to be worth it, but ymmv.
