Good advice, all. I appreciate these tips and experience. Keep 'em coming.
Bringing a square, level and straight edge/measuring tape is certainly imperative.
Originally posted by dms I didn't notice it/if anyone commented--you were planning on bringing a tripod?
I plan on having my tripod available, but doubt I will necessarily need it. I'd also like to avoid using the flash if at all possible, to avoid about excessively contrasty images, as RGlasel says. These images are going to be about representing the object and noise is forgivable for these utilitarian images. This case, like most cases, will likely be settled long before it goes to trial, but it is important to consider the audience when creating the images. I want to show the settings as naturally as possible, but in the most beneficial way for our client's case, obviously.
Legal work is funny. You've got the Plaintiff and their story. Then you've got the Defendant and their story. Then you've got the truth somewhere in between. It's always that way. You just have to hope you get an attorney that makes a better argument than the other one.
I think the K-30 and Mini-wide II will be capable for the task... but, without knowing the architectural features of the home, I probably ought to bring a zoom, too, eh?
Anything else you can think of will be considered and valued. Thanks again.
