Originally posted by JinDesu If the UV filter removed the purple fringing as part of its design, then it would also render other purple objects as black. That would be a pretty easy test.
Well... not necessarily...
I believe there's a difference between UV light that I believe is still picked up by a camera sensor (just like you can "see" the IR led on your remote with a camera) and purple = red + blue.
The fact that UV is rendered as purple is just because it's the nearest visible color on the spectrum, I think.
---------- Post added 02-11-15 at 08:14 PM ----------
...which brings the next question...
Is this Purple Fringing or Blooming?
There are few (255, 255, 255) spots (one in the middle of the engine), and none in the problematic areas.
Pic is exposed properly, RAW with no PP, 100% crop (plane's quite small).
It's f/11 so, yes, I stopped down and yes it's been the only time I've experienced something that bad with that lens.
Plane was far enough that I could use the infinity stop and it's not "color bokeh" or what's called, since it would have been green and not purple if I were near-focusing.
