Originally posted by amoringello Maybe just because a quick masking job was done, but these steps destroyed the chain.
(Edit: I realized I pretty much repeated Digitais' comments about the background, scrims, etc....)
Additionally, if you're doing this seriously, Translum Diffusion material might be your best solution.
It is a translucent plastic sheet that is more versatile and reusable than, lets say a white paper background.
Savage Translum Diffusion Background (54" x 18') 55418 B&H I looked at that translucent plastic sheets, and I may end up going there. I ordered a 1/8" thick 24" x 24" white 50% translucent sheet which is about the right size, cheaper and may be easier to handle than that 18' x 4' roll.
The masking is not the problem in Photoshop, but the change in the look of the background is. I can blur the background a bit, but then the glossy surface starts to look like satin. It is not a bad look, but not what I had in mind.
---------- Post added 02-16-15 at 01:01 PM ----------
Originally posted by bdery Move the background farther away, move the light source closer to the subject, try not to use such a small aperture!
Basically, that means go back to what I was doing successfully for all the pieces before this one. With this particular necklace, I wanted to get above it and shoot down because it had interesting links even back at the clasp. It also does not hang well on a necklace stand due to the large rose pendant. That is why I ended up raising the sotfbox, and the trouble started.
---------- Post added 02-16-15 at 01:08 PM ----------
Originally posted by tuco ..Perhaps consider bounce light instead.
I was thinking about some bounce as well.
