Originally posted by Popty Ping
I'm using the built-in flash on my K-R. I know a separate flash is better, but it actually gives better results than I expected. I understand aperture/SS/ISO, but I don't really get how flash impacts on those. I shoot in aperture priority mostly. I tend to shoot wide-open, but now I'm using a flash, I guess I have more flexibility - I do occasionally have focus point issues from the narrow DoF. Are higher d-stops an option?
I also don't really understand the impact of flash on shutter speed. I've generally found flash freezes the dancing. When I have experimented with shutter speed, I've found that varying it seems to have little impact - I tried to introduce a little blur at times.
Since using flash, I've kept the ISO low,but some online guides seem to say using higher ISO, particularly to introduce more background light - I don't get this.
Finally, my biggest issue is focusing. It's quite light by the standards of clubs and my sight is good, but I struggle to manually focus through the viewfinder. Is there a way around this? I'm guessing bigger f-stops will make it less critical, if it is possible to use them.
If any can offer any advice e.g. a good starting point for settings, I'd be most grateful. I've looked online, but found the guides a bit confusing.
Thanks
Si
Hi, I practice photography at salsa parties at Rico Latino in Enschede, Netherlands. Have a look at my work here:
https://www.facebook.com/media/set/?set=a.716273665115006.1073741873.128212733921105&type=3 https://www.facebook.com/media/set/?set=a.755404467868592.1073741875.128212733921105&type=3
Really, get the flash off camera, start with a spiral flash cord, you can upgrade to radio triggers later. Flash straight on gives this awful flat "deer in the headlight" look. Take the flash in your left hand, stretch your arm left and up and aim at your subject. You will get a lot more depth in the faces.
Flash has no impact on shutter speed. This is what you do:
Use the exposure triangle "aperture-shutter speed-iso" to let enough ambient light in. This will show the bar and the party lights. Get in early, take some shots with flash turned off to find settings suitable for the lighting. Black is bad, a bit underexposed is no problem, you pull up the shadows in lightroom afterwards. Noise will increase in the backgrounds but only a trained eye will see it.
Next, use the exposure triangle "aperture-flash power-iso" to light your subject. You will avoid motion blur because the flash duration is faster than 1/1000 of a second. When a light illuminates your subject you will see coloured light bleeding on the edges.
Flash power either means all manual like in the video or you use P-TTL and set flash exposure compensation if the faces are too bright.
I use ISO 1600 with K5II and K3. Nobody will notice noise when you publish on the web. High ISO is good for dance demos because flash output will be lower so the flash will recharge faster than when the flash gives full power at lower ISO.
My gear and settings:
K3, ISO1600, DA 16-45 f4 at f4 to f8, shutter between 1/3 and 1/60. I shoot RAW(dng)+jpeg. I use manual for portraits, aperture priority for the dance demonstrations, the shows are over in 3 minutes so there's no time to adjust settings. AV, iso1600, PTTL, RAW-DNG, develop in Lightroom, this will give me enough room to correct errors to get usable results.
Flash: Metz 58 AF-1 with Stofen omnibounce and spiral flash cord. Flash on extended left arm for portraits, flash in the hotshoe during dance demos. Also, I noticed some ladies have really fast eyes that close halfway from the P-TTL preflash. If this happens I set the flash to A mode where the flash uses the sensor on the flash body (on more expensive flashes). If you don't have A mode try manual mode.
No camera strap, it just gets in the way. I want to put my camera on a table or behind the bar to have a little dance and the strap gets tangled and increases the risk of dropping the camera.
The guy in the video talks about wide angle. I understand the need when the club is crowded but faces get big noses and chins when you are close up with wide angle. If I get the chance I move back at least 1 meter and use 30 mm or more to make faces look more natural. The ladies will love you for that.
Focussing: I use auto focus AF-S for portraits, focus, recompose. Center point is fastest. I use AF-C and move the focus point around for dance demos and dancers.
I hope this gets you further.
Karet
