Originally posted by Venturi Once you've converted from RAW to TIFF don't you also lose (or permanently apply) any camera settings that are stored in the meta of the DNG or PEF file?
Yes and no (actually many parts involved)
Your not supposed to lose all (or at least it's not necessarily the case) but it is program dependent. Lens data ect. can be preserved
As to the camera settings, i'm pretty sure you lose things like the white balance tag, saturation, ect. but they become really unneccasary as they are ,sort of , just the default processing parameters which the camera would use to create an in-camera jpg. Since your intent is to edit anyways, they become pointless. Base RAW data is changed on a save to TIFF ect. The TIFF is lossless and bit for bit conversion of the RAW file after editing.
Other things are the debayering and tone curve/gamma correction built into(or tagged) in the RAW file.
USUALLY nobody throws away the RAW, regardless of conversion, so all original data/tags/side information are saved regardless.
TIFFs, jpgs are just the "prints" of your negative but both could/should preserve the side data in the RAW file but this should never be assumed. Each camera maker puts things in different parts of the data file. One of the problems w/ propriotory RAW files.
RAW files, in many cases are just like subset of the TIFF standards. Pentax RAW was once said to be as closer to TIFF standards (or closely based on the TIFF standards) then most other manufacturers who changed whatever they wanted.
no sense re-inventing the wheel sort of.
TIFF:
The Unofficial TIFF Home Page
Nice graphic/tutorial on the formats:
Learn about RAW, JPEG, and TIFF with the digital photography experts at Photo.net.
Throw in "color space" and things get even more interesting.
wikipeadia quote:
Normally, the image will be processed by a raw converter in a wide-gamut internal colorspace where precise adjustments can be made before conversion to an RGB file format such as TIFF or JPEG for storage, printing, or further manipulation. Raw image format - Wikipedia, the free encyclopedia
