Originally posted by uday029 Thank you all for your valuable input. Since I am just starting off, my goal for now is to capture milky way with some nice foreground. I did look into OGPS1 but it blurs the foreground as the sensor moves. I am also researching on image stacking but I am not sure if it would work as the stars keep moving and their position would change relative to the foreground? Luckily, I live within 2-3 hour driving distance to Lake Tahoe and Mono Lake which have decent dark skies and good foreground opportunities. I am using
ClearDarkSky to check for sky charts.
Thank you stsimmer and philbaum for the links. I am hoping it will be a good learning experience.
I started doing some astro last year - both, with and with out the GPS unit. Your initial assumptions are pretty spot on. The conclusion I came to was, if you are including landscape in the foreground don't use the GPS and use the fastest lens you have available - wide open. If you are just going for the stars, use the GPS and you can use slower glass for the desired field of view. If you are going to stack, in order to stabilize (align) the stars positions, the landscape is going to blur.
Here is a thread I started about my adventure. It's more of just a running narrative (log) on both shooting and post processing. You can see that I was somewhat wandering around, trying things out, seeing what works - and doesn't. Both with and with out the GPS. It stretches across a few months. Also, the astro folks here on the Forum are absolutely wonderful. They provided a lot of post processing advice, suggestions, examples and encouragement. They had the knowledge and skill - I happened to have some relatively clear dark skies and a camera.
Here are a few quick take aways, that I found during my quest....
- High ISO is your friend. Depending on how dark it is, ISO 1600 @ 30 sec is going to be a good starting point. f2.8 if you have it - and adjust from there. I really appreciate the 31Ltd at f1.8 - to the point of thinking about acquiring the Sigma 18-35/f1.8.
- Bring a folding chair, and a red head lamp (REI @ ~$15-$20) and a wired shutter release, tripod and head.
- Focusing and framing in the dark is more difficult than it appears. Crank up the ISO all the way to 51200 @ ~5 sec for test shots, so that you can see on the camera's rear monitor what your framing is against the landscape. You can also check your focus this way. I used an ballhead, but have since picked up an old used gearhead (Manfrotto 410), so that I can make more precise changes one axis at a time.
- I like the old wide manual focus lenses, because at the end of the focus range its infinity (well for most lenses) - which makes focusing in the dark a bit easier.
- Bring a laptop to down load the images to for a real quick check to see if you did something stupid, or if you see something that you might lead you to try something different before you leave.
- You are going to burn through batteries.
- I just started locking the mirror up, since I was not using the viewfinder, SR should be disabled.
- Keep some notes of what worked and didn't, and what you want to try next time out.
