06-14-2008, 08:17 PM   #1
Stratman's Avatar
100% crop?
I see this a lot in posts of photos to show sharpness and detail. Would someone mind defining what it actually means? Does it mean cropping a small section, and NOT resizing it?
06-14-2008, 08:21 PM   #2
Buddha Jones's Avatar
That is exactly it, cropping a small section of your image while it is at 100%
06-14-2008, 08:45 PM   #3
Stratman's Avatar
Ahh, ok, thought so but wasn't certain, thanks Buddha !!
06-15-2008, 04:46 AM   #4
Thanks for asking this question, I had been a bit confused also by it's meaning.
06-15-2008, 11:21 PM   #5
By "100%" is meant that the cropped area shows pixels at a one-to-one relationship between image sensor pixels and screen display pixels. Hope you don't mind this small clarification, Buddha!
06-16-2008, 06:41 AM   #6
KrisK10D's Avatar
I'm confussed again, Chris. Your explination appears to be different to Buddhas.
06-16-2008, 06:49 AM   #7
rburgoss's Avatar
Ok, 100% crop means that the section cropped is at 100% size of what shows on screen when picture is viewed at 100% magnification in your photo software.
Normally, pics are displayed at 72 dpi. (72 dots/pixels per inch), so that means, that a 3000 x 2000 pixel photo (roughly 6 Megapixel), if you have a big enough screen, it will show at 71.5 x 27.5 inches. So a 100% crop, is a section of that picture at that size.
Now, consider this. At 72 dpi is only good for "screen". For printing purposes (minilab or your own printer) you need at least 200 dpi. For commercial use, you need at least 300 dpi. The same picture at 300 dpi, will have a size of 10 x 6.66 inches.
Hope this doesn't scramble things more.
RB
06-16-2008, 07:02 AM   #8
Gooshin's Avatar
QuoteOriginally posted by KrisK10D Quote
no, it is the same.
what buddha was trying to say is that you first take your image and view at "actual pixels" (at least in photoshop this is the command)
regardless of your monitor/resolution size you will now see the image at a one to one ratio of image pixels vs monitor pixels.
you THEN crop a section of that "actual pixel image" and post it here on the net.
camera, photography
How to make 100% crop alehel Digital Processing, Software, and Printing 32 05-05-2012 01:14 PM
Nature Reddish Egret a 100% crop Harish Hegde Post Your Photos! 7 10-27-2010 06:50 AM
People 100% crop 50mm Takumar WOW Taff Post Your Photos! 3 10-02-2009 09:05 AM
What is a 100% crop? kitkat Troubleshooting and Beginner Help 6 07-11-2009 07:39 AM
100% crop eccs19 Digital Processing, Software, and Printing 22 05-18-2009 11:09 AM
All times are GMT -7. The time now is 04:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
