Resources:
Astronomy Calendar of Celestial Events 2015 - Sea and Sky
The astro calender gives dates of astronomical events. Eclipses, full/new moon, meteor showers, etc. It also notes whether the Moon will be a problem with viewing meteor showers.
Heavens-Above
This shows passes of the ISS and other satellites such as Iridium flares.
Meteor Shower Calendar | American Meteor Society
The American Meteor Society website
Stellarium
Stellarium is a planetarium that is available as a cell phone app. Indispenable.
Take lots of batteries! Get comfortable. Take warm clothes. It can get cold on the Black Rock. Take a chair that reclines. Craning your neck to watch the sky gets tiresome quickly. If you're on the playa, there are no toilets.
Tie the tripod down. Take a jug of water and place it under the tripod and tie the tripod to the jug with heavy string. It will keep the camera steady if the breezes come up plus you have extra water. A flashlight with a red lens is helpful. Get one of the hands-free type. It's dusty up there. If you change lenses, get in the car with the windows rolled up. Turn off the car's overhead lights before it gets dark so that you don't shine on anyone else in the group when you open the door. Dim the camera monitor. It's very dark up there and the bright monitor will wreck your night vision.
The Perseids run from mid-July to late August with the peak on the night 12-13, so if the weather doesn't cooperate, you have several days on either side of the 12-13 especially since the Moon is approaching new. The radiant is in the constellation Perseus, where the meteors will appear from. Perseus will rise above the horizon at about 2200 Black Rock time but the best viewing will be after midnight. Perseus can be found to the northeast in the band of the Milky Way. Wider is better. Meteors will appear anywhere in the sky, so the wider the field of view, the more likely that you'll catch a meteor
High ISO. Your K3 will will easily handle 1600 ISO. Meteors usually flare for less than a second so the higher ISO may show meteors that were too dim for your eye to detect.
Turn off SR and NR. Since the camera is on a tripod, the shake reduction isn't need. Noise reduction (both long exposure and high ISO) will double the time between images. If you are doing 10 second exposures, the camera won't take another image for 20 seconds. (10 second exposure + 10 seconds NR). 30 second exposures would mean 1 minute between images. (30 second exposure + 30 second NR) That's half your time spent on noise reduction and maximum open shutter time increases the odds that a meteor will pass through the frame while the shutter is open. After it gets dark set the exposure to the longest you can get without star trailing. Try 1600 ISO and the aperture a stop or two down from wide open. Check the image and adjust as needed. When you're happy with the image, use the intervalometer to run the camera hands free. Set the exposure time and number of exposures and once you trip the shutter release, it's all hands free. You can do noise reduction in post processing. When you have the camera set to your satisfaction, put the lens cap on the lens and take a shot at that setting with the lens covered. You'll use that dark frame in post processing. You'll need a dark frame for each setting but that dark frame will work for all the images at that setting. Whenever you change the ISO or the exposure time, take another dark frame. You won't need a dark frame for aperture or focal length just for ISO and exposure length. Just do a web search for "Dark frame subtraction" to get instructions.
Aiming. The radiant is the point where the meteors appear to come from. In theory, that's where you'll see the most meteors but because they are coming directly towards you the trails will be short. About 30 degrees on either side of the radiant is supposed to be where the trails will be longest. You could also aim south to the galactic center and hope for some meteors to appear in the Milky Way. Since meteors are random and can appear anywhere in the sky at any time getting good images is a matter of luck.
