Originally posted by nanhi The beach umbrella was red in color, so I had a hard time with the white balance - turned our faces into red lobsters. The bright & sunny background under exposed the photos below the huge umbrella.
Not sure why there is a problem with white balance.... did you shoot RAW or JPEG; I notice you are using k-5IIs, it should not be a problem at all.
Originally posted by nanhi The patio was wooden decked and the camera on the tripod would vibrate each time someone moved, so I had to keep a high shutter speed. This shot up the ISO in TAv mode - and required some noise correction in PP. To make matters worse, folks moving about the huge round table would get cut out from the pre-composed frame - remember I was shooting with the camera on a tripod with the Pentax remote. One can't recompose in such situations, so many good shots were lost
TAv mode would cause problem in this case especially when you set the shutter speed too low in broad daylight. Noise should not be a problem as long as it is under ISO 1600 (in your photo it is ISO 320).
Originally posted by nanhi With all the sunshine around, it never occurred to me to bring the flash gun with me. And the camera's in built flash would cast a huge shadow due to the lens hood.
I would not use flash if at all possible; just try to avoid shooting into the shadow against bright background.
Originally posted by nanhi Required tedious work in Lightroom to get an appreciation for my effort.
Regards.
I was a lightroom user until I bought the latest Silkypix developer 6, which makes post processing much simpler and smoother. A few thing that Silkypix does very well compare to LR, you can use skin tone for white balance adjustment, auto noise reduction from RAW to JPG and the most useful one is group edits (same slider/control value applied to selected group of photos).
