Originally posted by Vitalii done some pictures today with 0.25 mm hole in copper foil.
Thanks to OzzRod, providing his pictures. I'm used to count every mm of sharpness, so itīs rather unconventional for me having such bad IQ.
Ps. Ozz, sewing needle got 0.3-0.5 mm depending how deep you.
will try to get even tinier hole, if there wonīt be much impact in iq, no sense in building adapters, or T/S stuff
Thanks vitalii; it's on the finer end as I don't push the pin right through.
Your image looks fine to me - I think the softness (and the simplicity of technique) is the real charm of pinhole images. The ongoing challenge is more in finding subjects, composition and light combinations that use the softness to best advantage. Cheers.
