Originally posted by photolady95 Problem with a tripod is, they are not easily moved back and forth to get a shot.
No offense intended but I dont know if I can agree with this due to the incredibly finite depth of field when doing most types true macro work overall. A: one can get a tripod that has the ability to get extremely low and be able to swivel the center column as mentioned previously. B. Adding a macro bellow or focus rail in conjunction with a tripod allows for that forward or backward movement needed much more precisely than hand held. C. Utilizing both allows for an extremely precise focusing ability for stacking photos for incredibly sharp detailed macro photos that simply can't be achieved hand held unless one is steady as the rock of Gibralter and has the eyes of a hawke. D. utilizing both allows for using time delay or mirror up and some type of wireless or wired remote to cut back any camera vibration which one can't do hand held.
Originally posted by photolady95 My suggestion would be get a monopod, if you really need something to steady the camera
Monopods IMO are ok for close ups but I can't agree one can be held steady enough overall for true macro work on a consistent basis.
Originally posted by photolady95 But mostly I just hand hold the camera because of the way you I have to focus. Moving the camera in and out to capture focus, manually focusing, as AF is useless in macro photography as it changes perspective.
Handheld may work for you but I wouldn't recommend it overall, IMO there is simply too much body movement for a vast majority of people to set and hold the camera steady enough consistently for the type of sharpness and depth of field it takes for true macro work. For close ups it's ok and one may get that occasional finite sharp photo hand held but one may wind up tossing more and achieving less hand held.
So IMO for the OP is get a good steady tripod and add either bellows or a focus rail
