Thanks guys for sharing some ideas.
Originally posted by UncleVanya I think the setting will dictate the lens.
Yes, at the train station, when the loco is stopped, it should be relatively easy to take shot of the engine, with a normal lens. Then the background may not be interesting.
Originally posted by WPRESTO DO NOT set on a tripod
Yes, it should be in day light, a tripod would be cumbersome. That a very good idea to have to parts where motion is frozen with panning and fast shutter speed, while other parts would be blurred... Wide angle, moderate wide would include some background depending on where I'm positioned.
Originally posted by cpobuttons I use manual mode and underexpose the scene by about 1 stop because the steam and smoke will really blow out on a bright day...shutter speeds of 1/250 to 500 seem to work...of course I dont know how fast your train is going to be moving... when the train enters the scene let her rip and have fun...
You are right, in sunny weather, I'm afraid to have the high-lights blown-up on the steam. The train will be green, so, not as big dynamic range as if it was a black locomotive, 1stop may not be enough, I shall use bracketing as well then and finish in post processing. I studied the map , I was looking for places when the train has to go up, so it may then be slower and produce more steam. There are also some bridges. Can be everywhere at the same time. But there will be several runs...
Originally posted by interested_observer The shots I have seen of moving trains (steam or otherwise) against landscapes, have all been distance shots.
The issue is access... So I may be close and far, depending on the location. I'll bring my 70-200, 17-50 or 28-75 not decided yet...
