Originally posted by micromacro I just wonder if someone uses in camera multiply exposure function for Orton like effects.
Usually not needed and there is more to it than multiple exposure. As noted above, the original technique involved printing from sandwiched slides, each of which varied by exposure and/or focus and/or colors. What you can do with digital is to clone the original image to layers in photoshop, modify each layer independently and merge back for the final. It has been several years since I have done an emulated Orton image, but IIRC the basic process goes something like this:
Create a new image with layers cloned from your original:Create a base high contrast monochrome layer Create a high saturation and moderately brighter color layer over that Apply Gaussian blur to the top layer Merge the top onto the bottom with transparency appropriate to your needs.
Edit: Probably best to ignore the struck out text. That is basically how I did the images below, but the merge was done manually. There are easier ways to get started with Orton and Google is our friend.
Here are a couple of images made using the above technique:
The intent with Orton is to create a sense of dreamy glow around the details and sometimes the effect is more subtle depending on subject and light.
