Originally posted by micromacro I failed my cemetery "assignment".
At least now I know what lenses worked the best there. Pretty much from 21mm to 300mm, depends of what needed. In most cases the range around 100mm worked well, but with clouds wide angle was good. The problem was mostly the wrong timing, it was such a bright and harsh day light, I even could not see settings in viewfinder.
I need to came back there.
(found an excuse)
That last image, it's impressive how sharp the background is, what are the details on it (f stop, focal length, etc)? I know this is the opposite of what you wanted, but nice all the same! The fine pattern on the statues arm is pretty interesting.
