Bad luck, hope it gets better soon. Sure is a terrible feeling when it happens. The already mentioned contact cleaner might help in very small doses. Helped my glitchy DS thumb dial (it didn't get wet though).
Dad once drowned his Olympus OM4ti on a canoe trip. It is sealed to certain degree but water got in the lens and viewfinder. Grabbed the camera and removed the batteries (luckily it wasn't on). Took back off camera, removed lens and focusing screen. Wiped up as much water as possible then layed camera body on car heater set to low and dried it on the way home. Hot as heck in the car since it was summer time. Once home put it in zip lock bag with packs of the moisture remover. Left it that way for about 3 days. Cautiously put batteries back in camera and it worked ( I couldn't believe it). More than 10 years later the camera still works fine! Lens was trashed ( cheap zoom wasn't worth the rouble to fix).
Hope your camera works again
thanks
barondla
PS If you have to send camera in don't mention liquid damage. Many companies will think the worst and refuse to work on it! If they figure it out fine. If not - you get your camera repaired. This is true even if camera is sent in out of warranty.
Check out POINT & SHOOT CONTEST 7 WINNERS in P&S forum. Enteries for #8 end tonight. Any type camera except slr. Any brand. Any subject. Enter now.
