Originally posted by fotograffiti Then, when you turn the focus ring to the infinity symbol, the stars will be in focus, without any doubts.
This couldn't be any further from the truth, just because a lens has a hard infinity stop doesn't mean it is guaranteed to be anywhere near accurate. Nearly every old manual focus lens I have ever owned has needed some adjustment to nail infinity focus. AF lenses, especially zoom lenses commonly treat infinity as a range instead of a single point of focus due to the inherent lower tolerances in construction, modern AF primes have tighter tolerances on this but they all need some degree of tweaking for precise infinity focusing.
If your camera has live view capability, push the exposure compensation up as far as it will go. This should amplify the light from stars that are bright enough to allow you to focus on them with reasonable accuracy.
Pentax K5IIs- SMCP-FA 31mm f/1.8 ASPH Limited.
