Originally posted by UncleVanya Yesterday I tried the film canister and found it to be no help at all with the LX7. It did nothing to reduce the flash glare. I tried a few other things - the one that worked best was the aluminum foil I folded into a square and held in front of the flash at an angle. Even then I needed to be really careful to get the tilt high enough to avoid have a part of the wall in front of me show a line of brighter light.
I wish I had a 3D printer... then I could fashion something that would fit over the flash and have the right tilt made of white plastic.
It's so small, the surface of a built-in flash.
I use a piece of Gary Fong Tupperware, the Puffer, which fits into a standard hotshoe, but it won't help you with your Panny.
